Is the yellow wrench and turtle lit up? have you read the fault codes in the battery? there is so many things in the battery that can cause this problem, software failure, water leaking inside battery, bad cell, bad master bms (2 of them) or a bad slave bms (16 of them) or bad contactor, precharge resistor or maybe a temp sensor..... but all of them are repairable and i wouldent go that way to get rid of all in the battery before everything else is checked..To all owners of Ford Azure Dynamics:
Hello I have a person who is an expert of these rechargeable modules. What he wants me to do is get raid of all these modules and install a new module and change all bad cells. I am still thinking what to do as my one charge only up to 30%. He name is Vjay and located at 445 Midwest Rd, Toronto, Ontario. Since you all have a better idea, what do you recommend?
Thank you sooooo much for your reply. I checked with the scanner and the scanner tells me in battery pack 0 to 5 cells are not reading. like you said it could be either Slave BMS or the battery. I ordered 10 batteries for Ali express and waiting for the delivery. Since those were shipped by sea cargo it will take time. Proverbially I might get those by end of November.Is the yellow wrench and turtle lit up? have you read the fault codes in the battery? there is so many things in the battery that can cause this problem, software failure, water leaking inside battery, bad cell, bad master bms (2 of them) or a bad slave bms (16 of them) or bad contactor, precharge resistor or maybe a temp sensor..... but all of them are repairable and i wouldent go that way to get rid of all in the battery before everything else is checked..
HiThank you sooooo much for your reply. I checked with the scanner and the scanner tells me in battery pack 0 to 5 cells are not reading. like you said it could be either Slave BMS or the battery. I ordered 10 batteries for Ali express and waiting for the delivery. Since those were shipped by sea cargo it will take time. Proverbially I might get those by end of November.
These are the links to order battries.Ron_84 I found information on the forum that you have parts for Transit AZD. If you still have a battery, can the cells be sold and shipped to Poland?
please reply to the e-mail: [email protected]
These are the links to order battries.Hi
If it's not a secret, what was the cost.
I need full 96 cells.![]()
This is not the same listing what I posted. But the batteries are the same. If the listing is active. you have to make a complain to Ali express management.
definitely I will post here so everybody can see.Hello
Yes, this listing is not the same, I just wanted to compare.
Could you please let me know, if it will be possible, about result?
I did exactly that, I decided to ask if there are more opinions and explanationsYou just need to measure the voltage on the new batteries and, if possible, adjust to the battery voltage.
Then charge.
