Hi
I have a EMUS bms in a Think Classic in combination with battery moduls from a VW e-Up. The BMS have a SOC signal PWM 0-5 volt and 7,8 kHz, but the original instrument cluster in the car needs a PWM signal 0-12 volt and 200Hz.
The 7,8kHz signal is to fast to be aceptet by the SOC instrument.
Does anybody knows an easy solution too convert the EMUS signal from 7,8kHz to 200Hz?
