One thing confusing when you say 3p2s is you're talking modules, not cells. We normally discuss XsYp when talking cells, not modules. People do it a lot with Leaf cells and it's confusing.
So it looks like you want to build two 48s packs and parallel them. Correct?
If you want to balance, you'll need either a BMS that can do it, or hand balance the cells, which is a huge PITA. I'd look into Zeva BMS a little, as they're priced well and modular. They're 12s, but you can make harnesses so you'd use 4 boards for your 48s pack.
For charging, you want to charge just a single 16s pack temporarily? or do you want to charge the entire 48s pack? I suggest buying a charger that meets the final need, not the immediate desire.
If they're resting at a good voltage, don't worry about balancing until you're ready to install in vehicle, and charge/balance then. You don't want to fully charge them and let them sit for long periods. We recommend having maybe 50-60% SOC for storage. Charging to 100% and leaving sitting is not recommended by many battery manufacturers or OEMs.
