While I bought my AC motor a few years ago, it looks like there is another AC motor on the market.
http://www.go-ev.com/Motors-AC.html
What do you think of this motor and the specs it has?
http://www.go-ev.com/PDFs/HyPer_9_Graph.pdf
My issue is more on the use of "integrated" and I think that they need to add more components into the controller to make conversions simpler. With those types of amperages, I would assume that the controller will need to be cooled, is that system included? If they could include a start button option with a pair of key fobs, that would be good. There is the DC-DC converter, vacuum pump, 12V battery connections, and displays. And I will even go as far as integrating a battery charger and J1772 socket that has wires that can be plugged in to this.
It would be nice to have them sell a drop in kit that makes conversions as easy as connecting the batteries, the motor to the transmission, and these electronics component to the frame.
Or if they are separate components, still sell them as an entire kit that works together with the wires and fuses.
