1 - 5 of 5 Posts
I'm looking to use a NetGain HyPer9 AC Motor to power my bespoke EV, but I'm not sure which transaxle to use. Could anyone suggest what options I have in this respect?
I've been told that I should perhaps consider a Porsche G50 transaxle as these are robust enough to handle the high torque levels of the HyPer 9 motor. But, for me, this is a clumsy approach as I don't need several gears and would prefer a direct-drive setup.
Therefore, could anyone help me to decide how best to transmit power from this motor to the rear wheels of my EV, please?
What overall gear ratio do you need between the motor and the axles?
Do you need multiple ratios (a multi-speed transmission) or only a single ratio?
With one motor and two wheels you will need a differential; do you need any specific differential features or capabilities, such as limited slip or torque vectoring?
How should the powertrain be packaged: motor ahead of, above, or behind the axle line? Transverse or longitudinal motor shaft?
What kind of car is this going in? While it is a fantastic gearbox, the Porsche G50 is a $5-10k transmission, and they are not cheap to rebuild.
I would sooner try and make a Subaru transmission work in its place, as the aftermarket is huge for them, and they can be had for cheap. VW/Porsche adapters are available.
None of the questions I asked (almost a year ago) regarding this proposed project were answered - I don't think the original poster understands his requirements or is willing to discuss them. He has since shifted to looking for a consultant:
EV Powertrain Expert Required
I don't think there's any point in continuing the discussion of the HyPer9 or G50 for this project.
1 - 5 of 5 Posts
