It's only bigger and heavier until you consider the stuff you have to throw in to make other controllers a functional system. A couple extras the Soliton 1 has going for it:
1. The contactor and precharge circuitry are built in. That makes for a more robust system and elegant wiring layout. It's also a few less components you have to purchase extra.
2. The water cooling is not required (depends on the application). No extra heatsink or cooling fans either. My dual controller/motor setup runs cool as a cucumber with just the air cooling they came with.
Just some thoughts to consider.
Steve Green
Steve Green
