That is a lot of ah. I can go 100 mph with my 200 ah pack, but 14000 ah may be a bit too heavy.
very goodI am sure it is 14400 ah.
The voltage for each battery is 3.2 V
The mystery of 14400ah is solved!There will be 72 batteries in total. Each one is 200 ah and weighs about 5.70kgs.
72 x 3.2 = 230vBut I only 144 volts for the motor.
72 batteries X 3.2 volts is 230.4 volts. That is too much!!
What do I do?
I really want to use a ac motor.72 x 3.2 = 230v
You can have 230v and 200Ah
Single string all cells in series
Or
two strings of 36 x 3.2 = 115v
115v and 400Ah
Two strings of 36 cells in parallel (2 x 200 = 400Ah)
Or you can use a DC motor - (Warp 9/11 or ex forklift) and a Soliton Controller that will use 230v and drop it to a lower voltage for the motor
I really want to use a ac motor.I really want to use a ac motor.
If I use a controller to lower the voltage, am I wasting charge from the batteries????
I think your two string solution might work for me.
