new lifepo's from Alibaba...too good to be true?
2585 Views 4 Replies 3 Participants Last post by  DansEVhobby
do you think these are any good? they claim to be 3.2v 200ah cells for $28 a piece!
1 - 5 of 5 Posts
The discharge rate is listed as 1C, which wouldn't be enough for a typical automotive conversion. For instance, if you string 40 of them in series for a roughly 120 V (nominal) 26 kWh pack, you can only get 26 kW (34 hp) out of it (128 V * 200 A). Perhaps they can safely operate at a higher discharge rate in short bursts, but the listing doesn't claim that.
thanks Brian, what would be a good discharge listing for lifepo's? If it says up to 5c would it mean it can handle 5 times the kwh? Can you explain a little more I'm a total noob.
I would say that Will @ DIY Solar Power with Will Prowse has tested MANY batteries from across the Pacific and more than a few are a good buy. I would use what has been tested to know the value proposition.
what do you guys think of these?
130ah 10c max discharge
anything I'm missing that makes it not ideal for an EV pack?
1 - 5 of 5 Posts
