Hi all,
I've been working on software for Damien Maguire's CHAdeMO controller. I've finally succeeded in quick charging my car, so it's more or less ready for prime time.
It uses the SAM3X (Due) MCU and an Isabellenhuette IVT or IVT-S shunt, support for different sensors is possible.
Standard CHAdeMO power limitations, 125A and 500V.
Configurable voltage and current limits, BMS info via CAN, and readily available software.
If you'd like L3 charging for your conversion, this is the cheapest option I am aware of. For less than $500, plus a CHAdeMO port, you can have 50Kw charging.
Everything is fully open-source (I guess mine is under beerware) for the greater benefit of EV converters everywhere.
Documentation is spread out a little, but my guide and more info is here, along with links to code.
SAM3X CHAdeMO - v2
Happy charging!
-Isaac
SAM3X CHAdeMO - v2
Happy charging!
-Isaac
