The Corvair van is an interesting conversion target. If you just mount a motor in place of the engine (using the original transmission), there isn't a lot of space for battery modules. There are a few interesting possibilities:
- replacing the engine and transaxle with a complete drive unit with the motor ahead of the axle line (if it fits) would leave the entire engine space for battery;
- the transaxle appears to come apart into final drive and transmission sections, so the transmission could be replaced by the motor (and likely a reduction gear unit), keeping the final drive portion and leaving the entire engine space for battery; and,
- the factory optional "level floor kit" could be used to create both a level load floor and a large battery compartment in the middle of the truck.
It would be a shame to lose the low floor and rampside loading, but the battery needs to go somewhere...
It's too bad that the van never got the car's improved rear suspension design - it stayed stuck in the first generation mechanical design (and body style).
