Hi
Your ideas about running a generator to increase mileage are just plain wrong (unfortunately)
A car engine is MORE efficient than a generator engine
And then you come to the efficiency of the conversion
Chemical energy - work (engine)
Work - electricity - (generator)
electricity - work (motor)
Every time you convert energy the gods of engineering take a cut!
And your generator system has two extra steps
A hybrid (like a Prius) is only more efficient because it can run a super efficient engine cycle and regenerate braking energy
And on a long run (highway) a Prius is not actually more efficient than an ordinary car
The reason that your emergency generator will run for a while is that you are not using anything like the power that your car will use
Rough figures - a house uses about 20Kwhrs/day
(with everything running - not in emergency mode)
That will take a car about 60 miles
