Hello all, I am new here from Ontario Canada.
I have a 2001 F-550 2wd cube van with the 7.3L diesel.
I am totally new to electric vehicles and Researching my project led me here. My crazy idea is to swap the front axle for a 4wd one and power it with a forklift motor using the original forklift batteries charged by plugging it in at night. The purpose is to add horsepower in order to save fuel. Not to drive on electric power alone.
I am a mobile heavy truck mechanic and the truck is my service truck and my livelyhood. Using the Dana 60 front drive axle will allow me to unlock the hubs and isolate the electric system in case of malfunction so I can keep working. I plan to use a stock front drive shaft and mount the electric motor to the frame near where the transfer case would have been.
Here in Ontario used electric forklifts can be picked up for $2-3000 with a charger. I plan to use the batteries, motor, charger and control system from the forklift and sell or scrap the rest. I'm hoping to recover enough to get my cost down to around $1000 plus the axle and drive shaft (appx $400). If the system works I plan to upgrade to lithium batteries in the future.
The axle I have has a 3.73:1 ratio and with the 225/70R19.5 tires the input rpm should be appx 2500 at 100kph. I don't know what rpm forklift motors run at. Is 2500 rpm doable?
Any advice or direction will be greatly appreciated.
Thanks,
Dana
