I've been doing the occasional look on alibaba for batteries, found another one that is very affordable, well without knowing shipping costs. Would like advice on using these batteries and my analysis. Alibaba is a freaky website, they always want me to download an app, here's a search that got me here on alibaba. "lipefo4 battery 3.7v 135ah oumeida". Here's the link:
3.7v Lithium Ion Battery 3.7v 135ah Rechargeable Battery For Electric Vehicles 3.7v135ah 3.7v Battery - Buy Ternary Lithium Battery 3.7v135ah,3.7v Battery,3.7v Lithium Ion Battery Product on Alibaba.com
Editing my mistakes (milliohm, not microohm)
Specs
The inverter is 480V max, 480V/4.2= 114 batteries. 421V nominal.
114 batteries => 57 kWhr
228 batteries => 114 kWhr
$29 ea at 228 volume, $6,612 plus shipping and plates, etc.
3C discharge for 135ah battery means 3x135=405A. 5C=>675A
Two in parallel gives 810A, the motor looks like 730A peak, 300A continuous.
At peak current, 730A, 365A per string.
365A * (0.4 milliohm) * 114 = 16.7 V drop per string at peak.
(365A^2) * ( 0.4 / 1000) *114*2 = 12 kW generated at peak
(150A^2) * ( 0.4 / 1000) *114*2 = 2 kW generated continuous max
That's a lot of watts!
2.25kg x 228 => 518 kg, 1130lbs.
The temp specs, -20C to 60C, haha, i have eye dr appt in a week because these glasses are way off...
What do you suggest for heat/cool? Cold plates inbetween on the 140x175 end? Would plates on the 50x140 surface work or the 175x50 surface?
If these are something I can really make work, it's much more economical than the used tesla batteries I've seen, but also very heavy.
Thanks!
Mark
Specs
- 3.7v nom, 4.2V cut-off, 4.2V charge voltage, 3C-5C max discharge, 3C charge, 0.4mohm resistance, 20C-60C operating temp
- dimensions: 50mm x 175mm x 140mm
- 135ah x 3.7v => 0.5 kWh
- 2.25kg
Thanks!
Mark
