These batteries are of a similar type to those being used in off grid home power solutions. I am currently monitoring the Lifepo4 market at the moment for that reason. I can tell you that as each new battery model comes out, the older ones drop significantly in price. It is a fast moving market.
For example, the release of the latest 304ah Lifepo4 batteries instantly caused the superseded 280ah models to drop in price. Currently you can save around 25 to 33% in value by choosing the 280ah model. So older models like the ones mentioned in the op can be bought for very low prices.
Also, the latest models are all being set up extremely successfully to charge to 3.45v and working down to 2.8v... with very little degradation. If you want to operate between 2.5 and 3.7v as the specs say, they will work, and you might drain another 5ahrs out of each pack, but your expected battery life will plummet 100s if not 1000s of cycles.
