Next Gen Electric Supercar
4314 Views 26 Replies 8 Participants Last post by  snowdog
Hey Friends,
I am starting on the journey of building another electric supercar.
Still in the planning stages. Here is my thought...I would like to take the cockpit of a modern car and strip most of the exterior for my own unique exterior design. As far as drivetrain, I was thinking all wheel drive. My first thoughts go to tesla as I have done that before but anything is on the table. Also looking for battery suggestions. My thought is something smaller and more modular and smaller (less weight) than the tesla packs, but that is also an option.
If you are looking for more details, check out the video.
I look forward to your suggestions.
21 - 27 of 27 Posts
Glad to see another 981 conversion!
Watched the vid last night.
Reach out if you want to talk a bit more!
981 Build - Openinverter Forums
I skimmed through your Openinverter forum posts. Looks like I should be talking to you about CANBUS manipulation
So in the end, the project will be an EV conversion of an ICE car, converting from RWD to AWD at the same time, using production EV drive units, and with body customizations. The overall shape, interior, structure, and complete chassis (suspension, steering, brakes) will be Porsche 981 Cayman (and those are good things :)). The Cayman and Speedster are a bit oddball in today's world, having MacPherson strut suspension both front and rear.
With the original style of drive units from the Model S, both front and rear motors will be behind the axle lines. In the front that presumably uses some of the fuel tank space; in the rear it will extend into or under the trunk. That leaves the original engine space as the major opportunity for battery location, which is good from a mass distribution point of view.
Major challenges will presumably be fitting in enough battery, and keeping the rest of the car working with the powertrain replacement.
It should be an interesting project, and nice car to drive.
Reactions: 1
If you haven’t already done so you might want to look at Forge Space channel on YouTube. He is doing an awd from a Tesla 3 in a DDR kit. You will have to deal with some of the same space issues he has.
More Teardown. Losing 400-lb
21 - 27 of 27 Posts
