I was looking for some LiFePO4 18650 cells to replace the dead NiCDs in a Ryobi 18V portable drill, and I found some 2500 mWh NiZn AA cells for $32 for 16 pieces.
http://www.ebay.com/itm/16-pcs-2500...Rechargeable-Battery-PowerGenix-/151256251587
This works out to about $0.80/Wh. The LiFePO4 18650 cells of which I have four were labeled as 3600 mAh but tested out as about 1100. The ones I found recently are labeled 1800 mAh are $25/6 pieces which is $0.72/Wh but if they test at 1100 (which I expect) they would be $1.18/Wh.
I also found some AA (14500) LiFePO4 cells rated 700 mAh at $15/8, which is $0.84/Wh, but they are probably also over-rated:
http://www.ebay.com/itm/360874869583
The four LiFePO4 cells I bought almost two years ago still read about 3.78 volts so they seem to be good quality, but just lower than stated capacity. The NiZn cells supposedly have a much higher self-discharge especially after about 30 charge cycles, but otherwise their characteristics are pretty good, according to Wiki:
http://en.wikipedia.org/wiki/Nickel–zinc_battery
I only need 18V for my drill and I have found that it will work satisfactorily down to 12V, so the four LiFePO4 cells I have should work OK down to 3VpC. I plan to incorporate my most recent design of a BMS/shunt charging circuit in the drill to prove its features. I can modify the circuit for the 1.6V nominal NiZn cells, by assuming two in series will remain well balanced enough, or I can add an extra voltage sensor and shunt element.
A major plus for the NiZn cell is low toxicity, recycleability, and inherent safety, as no flammable materials are used.
I will only need 12 of these cells for my 18V drill, so I will have 4 left over as spares, or for use in other equipment that uses AA cells.
Does anyone have any recent experience with these? Thanks.
