1 - 11 of 11 Posts
So I bought a Leaf motor....
it was delivered as a puzzle!
For general interest...pictures of a 2018 inverter..
Haha yes the car was driven into the back of a commercial truck... so the 'top box' was sheared off.
the inverter only seems a bit damaged at the big capacitor block (by pullin on the copper input terminals, might be electrically ok.
The charger / junction box have two levels, the top part wasn't to badly damaged. took it all apart for recycling, only saved some contacters and a diode :p
With some help I want to try if the inverter /motor can be controlled by CAN with the same protocol as earlier Leafs. Will have to find out pinout first...
Also quite busy so might take a while.
The 2018 Inverter looks different from older models I have seen so be prepared for the fact Nissan may have also messed with the CAN messages to drive it. Also I doubt anybody else out there has access to the newer model Leaf yet and if the messages have changed you will need another working one to analyse and figure out the right messages to send.
Alternatively the IGBT and driver board would probably work fine with one of the open source controllers mentioned elsewhere on the forum.
Both ways unfortunately require a bit of technical knowledge
The IGBT is rated at 700A / 650V, its definitely a beast!
1 - 11 of 11 Posts
