1 - 4 of 4 Posts
I'd like to hook an aftermarket BMS to my Leaf pack, and I'd like to reuse the Leaf wiring. To avoid taking the bus bars apart to see which cell connects to which pin on the BMS, I'm wondering if anyone has done this before? My BMS has the black and gray connectors...The manual is helpful, but doesn't seem to answer this question...I would expect there to be 96 taps in total for the 48 modules in a full pack.
Random internet photos:
Thank you for sharing the wire harness layout. I would like to get the date sheet about the module to operate the system. If you do not mind, could you share the documents and the information?
I would like to get the PIN information about 24V (Power output), GND, H-CAN and L-CAN from LB11 to LB16.
Thank you in advance.
1 - 4 of 4 Posts
