Hi, I'm new in the forum. I'm converting an old Westfalia into 100% electric using Nissan Leaf components. My question is about the resolver (position sensor) of the electric motor:
Basically, I swapped 2 (of 3) phases of the Nissan Leaf AC motor to change the driving direction (Because installed the other side). When I try to spine the wheel, nothing happen and I suspect the resolver.
The Nissan Leaf electric motor position sensor: p/n: 34VRX-1004-C01S
Here's my questions:
1) What are the 6 wires going out from the resolver?
2) Is it a 10 poles/ 3 phases / 4 magnets resolver? Where can I find a wiring diagram and/or a schematic view for me to understand?
3) Do I need a new custom resolver for my use or I can just retrofit the existing one my swapping wires? If yes, which wires?
Thank you very much! Help will be very appreciated since I'm stock.
