Go pedal's in! I was planning to use the stock pedal with a cable-operated box, but my research showed that potentiometers were short-lived and unreliable and lever-operated Hall Effect boxes were...expensive. Cable operation seemed more complicated than it was worth.
So, I grabbed the Leaf pedal and fabbed up a janky "pedestal" for it using 1/8" angle-iron and the stock mounting bolts. I just eyeballed it in place, using a photo of the stock setup as a guide. I got it in a good spot the second time around.
Those stock mounting bolts were way too weak for the new leverage on the pedal, so I also added a triangulation "spar" to the floor...I might bolt it down, but I'm gonna give it a try first.
