Hello all,
looking for some insight and assistance with a project I'm putting together.
This project is me putting my toe in the pool of EV to learn and use in larger projects.
I would like to use a Leaf motor, inverter, charger assembly for my little project.. They are reasonably priced and more easily had than the Tesla units. Anything Tesla automatically makes the $$$ rise. If it was a Tesla Leaf it would be more $$$.. And my little project could probably use less power than the Leaf puts out.. But who doesn't like More Power!!
So.. to my quest for Leaf Info..
I plan to use Tesla Smart Lithium Ion 18650 modules (Yes very hard to get ahold of) but my project is space limited. I actually have to build the chassis around the modules I plan to use. The Smart Tesla Packs house 6 modules that puts out around 57 volts at 18 kWh. I am using 12 modules for a total of 684 volts and 36 kWh.. Not that I plan to dump all 684 volts into the assembly.
I also saw this configuration used on a UK EV Youtube Video. But I doubt they used a Leaf assembly.
So the Leaf has 30kWh, 40kWh and I think 60/80kWh abilities. Can I use the 36kWh set up I mentioned to power a 40kWh assembly or do I have to find a 30kWh assembly?
I am thinking if I can lay hands on an assembly rated at 40kWh. and I won't be exceeding that with my 36kWh set up. I will be fine.
The two limiting factors to my project are the batteries (which I have squared away) and the motor assembly (which I'm still trying to figure out) the rest (for me) is connecting the dots.
Any assistance would be a great help..
Thx,
Kev
Thx,
Kev
