Hello! I have an Electric scooter (goped) and have some questions about the batteries. The system is 60v (Lead Acid) and at ~66 volts the charge gauge shows 100% (though it drops to 64v/~90% pretty fast) and under normal load on a flat surface it'll drop down to 60% and when it reads 0% (50v) under load it'll read 35-40%(~58v) with no load. At no load 35% it barely has the power to move.
So my questions are, should I calibrate the charge gauge to say 100% under load when charged or should I just leave it and be happy with the 60-0% I can use? And I also noticed that it dropped to 47 volts when I climbed a hill! Thats less than 10v per cell, will that cause any damage to my pack? What happens when the load drops the voltage to far? ( i have five 12v in series)
