Well, you have options, that for sure.
With a good budget and a lot of interest, you can build a conversion to get you on your commute. But, if you are not confident in that, you can always buy a leaf, which has the range/performance you need. It's definitely time to get off the dino-fuel though.
Also, if you check out the ZERO Race, www.zero-race.com, you will see that they made some great EVs that are light-weight and getting great range and speed.
Electric cars can be whatever you want them to be, but you just can't get everything at once. There is the issue of energy storage but 20 miles even with hills and freeway driving sounds very doable if done properly. Sounds like you will almost definitely need to go Lion.
Welcome to the board.
