Hello,
I am looking to abandon gas entirely and build a commuter car. I have been living fully offgrid for 6+ years and can build a wide range of lithium batteries myself.
Its time I left gas behind. I need help determining the best setup for a simple commuter as far as motor, controller, subsystems, charging. I am building the battery myself. It will be capable of 300a Continuous, at whatever voltage is needed, using LiFePO4 Chemistry Grade A cells and an appropriate BMS.
My parameters so far are as follows:
Donor car types being considered (Honda Insight lightened up, VW bug/beetle with a lot of fiberglass replacement parts, GEO metro stripped lightened, Geo Tracker lightened, etc.) Simpler onboard systems the better. (Crank windows, manual everything, as light as possible, easy to interface with signals and breaks. Retain power boosted breaking if possible)
AC not required. I'll live.
Range needed = 55-65 miles one way
Top Speed = 60-70mph
Acceleration - Not important - Turtle slow is fine, just need a decent cruising speed for my commute. Slow lane get me there, type car.
Voltage = 96V - 144v DC system if possible.
Motor = Preferably AC motor setup
Battery = Self built LiFePO4 300ah - 3x 100ah Packs at whatever config is needed for motor voltage requirements.
Terrain - Florida FLAT - No hills
Nice to have a radio, personal fan, 12v accessory plugs
Want to have ability to tie a solar array to the car for charging.
I have space at work and at home for a 2-4kW solar array to charge with.
Would also like the option to Generator charge @ 110v with a smaller inverter Generator if needed. (Emergency use only if stranded)
I need help determining a motor setup that is as LOW COST as is possible, but I am willing to spend 4-5000$ on the battery, 4-5000 on Motor and controller setup, and 2000$ ish on my donor car. Initially.
I will upgrade and extend range as I go.
As I am already spending 10,000$ a year in gas for my ford F-150 as it is, I'd prefer to park her, and use her only for trailer pulling occasionally, and commute full time in an EV of my own make/design. A 15,000$ build is what I am expecting, with 10,000$-12,000$ just to get started.
But, I am new at conversion, and need HELP to get to the finish line on this one without screwing anything up.
Particularly, I need help determining a decent motor and control setup that is both hearty, and can be had for my 5000$ budget for that part.
I need to be able to cruise for almost an hour at minimal highway speeds to get to and from work. If I need to add cooling, so be it.
Batteries and charging I can handle myself. Batrium can deal with a pack of any series width, and I know it well. I also know how to build and size solar array's/stations to handle the charging. Finding/making the right gear to get the pack charging optimally at the needed voltage will be a challenge, but I can split the pack down smaller for charging with solenoid disconnects if needed. So I would like to stay within multiples of 48vdc to use off the shelf MPPT controllers and chargers to get recharged.
Please let me know what your thoughts are. I am hoping to build the car this year, and I understand this is not an easy project.
I have the time and energy to get it done. But not the full technical understanding of the motor and drive components to guarantee i can reach my desired speeds and range.
Thank you for your time/help in advance!
Steve
Steve
