1 - 5 of 5 Posts
[onaprsc.com.vn] make many products automatic voltage stabilizer call [on ap standa], [on ap] and machine automatic battery charging technology uses controlled pulses (PWM), is controlled by the advanced electronic circuit enables safe operation mode, can effectively meet the load demand for a variety of different batteries. Conversion efficiency high energy, save electricity, much better than the battery charging machines using conventional transformer. It has the ability to control the status of the battery is full, the system automatically adjusts the optimal load in order to improve the quality and prolong battery life. In particular, stable charging regime does not depend on the large fluctuations of input voltage-on ap standa
Specifications:
1. Input voltage:
+ Wide input voltage from 120V - 250V/50Hz. Being able to provide a steady flow does not depend on the large variation of voltage inputs.
2. Features:
+ Auto Reload, fast loading, load regulation for the maintenance of lead-acid batteries, sealed, lead-acid batteries commonly used water poured on the market.
+ Load versatile for all kinds of different capacity battery (can load arbitrary line set by the battery capacity)
+ Features desalination lead sulfate crystals on the plates, maintaining and improving the quality of life of the battery.
+ High conversion efficiency, power-saving absolute safety equipment as well as batteries
3. Battery type:
+ The 12V lead acid batteries
+ Battery Capacity: 5 - 200AH
+ Suitable for start batteries, standby power batteries, UPS batteries ...
4. Load Mode:
+ Maximum load current: 10A
+ Auto Reload, load stability limit line voltage, load 3 stages
+ Break automatically loaded when the bottle is full, reloaded with the average voltage
5. Safety and Protection + Protection by electronic circuits: reverse pole protection, output short-load, over-current, over voltage ...
6. Size: 160x160x200 (mm)
Trang web official of On ap Lioa Output and Thương mai trên pressure variable pressure Nhật Linh, we always updated information and San Pham Gia Thanh latest. Quý guest please call to power to the bo phan ban hang online
Tai SHOWROOM to be tu van and Báo giá điện lạnh quick Chong
Số Hotline: 0913 306 513 - Mr Vĩnh
Keyboard Máy: (04) 3552 3847 - Fax: 04.3355.4669
Công ty Cổ phần Standa Việt Nam chuyên sản xuất ổn áp Standa và Phân phối ổn áp Lioa giá cam đoan tốt nhất trên toàn quốc. Sản phẩm chính hãng với 100% dây đồng, bảo hành 04 năm, giao hàng miễn phí khu vực nội thành Hà Nội…
Qúy khách vui lòng gọi theo số Hotline 0987.621.590 hoặc truy cập Website http://onaplioa.info/ để được tư vấn và hỗ trợ. Chúng tôi có Lioa và ổn áp của các hãng khác..
Xin cảm ơn!!!
Specifications:
1. Input voltage:
2. Features:
3. Battery type:
4. Load Mode:
thank you!
Specifications:
1. Input voltage:
2. Features:
3. Battery type:
4. Load Mode:
1 - 5 of 5 Posts
