I have 1967 VW Beatle that I am converting to electric. I have a D&D 72V DC Motor, Alltrax Controller SPM 72400, contactor is SW 180 with coil Suppression Diode and pre charge resistor. Batteries are out of 2013 Chevy Volt(lithium cobalt) have 6-72 Volt Packs that run the car.
I am having a hard time trying to find an onboard charger that will work with my system. I hope you guys can help? I was looking at your TSM2500 and was wondering if this will work>? I am looking for something that will work in normal 110V household outlet.
1-72 pack have: 18cells
3 KWh each
70 AH
Average/nominal charge 3.8VDC
Any help recommendations with Charger/BMS would be appreciated.
Im new to the EV Build and need assistance/direction on chargers & BMS? Thanks
3 KWh each
70 AH
