I see in the specs that the max ambient inlet temperature is 70C, but what are the max operating temperatures that I will see via CAN? I have a virtual dashboard that I am picking the green/yellow/red arc segment values for. I have read the outside can reach 100C. I see the Inverter and Motor temps regularly in the 50-70C range, when should I think there is an issue that needs design alteration?
I am also curious about the values for the Azure DMOC 645, max inlet temperature 55C...
