1 - 2 of 2 Posts
I see in the specs that the max ambient inlet temperature is 55C, but what are the max operating temperatures that I will see via CAN? I have a virtual dashboard that I am picking the green/yellow/red arc segment values for. I see the Inverter and Motor temps regularly in the 50-70C range, when should I think there is an issue that needs design alteration?
I am also curious about the values for the Siemens 1PV5135 4WS14, max inlet temperature 70C...
It's only an issue when the DMOC starts to reduce power (it is built for OEM vehicles so it integrates safety features). I believe that happens when a sensor reaches 85C (which happened a lot with my air-cooled DMOC).
-Isaac
1 - 2 of 2 Posts
