1 - 3 of 3 Posts
Absolutely. The Orion 2 has all the capabilities you'll need (as do a few others).
Here's what I learned about the Orion and Tesla modules:
There's six cells per module. So five modules is thirty cells. On the face of it, an Orion 2 -36 would work, and it does..BUT...if you have anything like a fuse, cutoff, or other high resistance between your first and last cell you may need a different model because of the way the cell tap wiring is done on the Orion. I have six modules, 36 cells. An Orion 2-36 works but I have a mid-pack fuse and cutoff so the proper unit is the 48. The Orion website has a diagram generator and guidance on which unit to get. My advice, flesh out your pack plan as best you can before you buy then buy bigger.
1 - 3 of 3 Posts
