In cases that I have limited space and can only fit so many batterys in certain spots. Just seeing if there are ways of doing it. I have nothing to put it in yet I'm just trying to understand some things.Why would you do that, vs split the 12s4p to two 12s2p, and what is it for?
Like I said in my first post it is just an example.I'm confused. Why was 12s4p being considered at all? Two 12s2p fit...
That doesn't sound right.No, nobody does this.
Adding a 4P in parallel to a 2P module does not make a 6P pack--it makes a 2P capacity pack. Like a chain, a pack is only as strong as the weakest link.
Not necessarily true. Since parallel is basically a circuit between two batteries, the paralleled batteries will self-balance their voltages to match, and the current draw from each paralleled battery will be proportional to its total capacity. The 'weakest link' analogy is very true for series configurations, not for parallel.No, nobody does this.
You can add modules in series to adjust the overall voltage, like a 4S plus an 8S to make a 12S pack, but all the modules must be of equal Ah capacity (same "nP " size)
The OP is asking about putting two packs in parallel.For the same weight of pack, and for flexibility of placement, you would never put a 2p in series with a 4p, you would put three 2p in series.
It was always at 6p. 12s4p plus 12s 2p equals 12s6p. It fine if that's not how it works but 6p was the end goal in that EXAMPLE. And again there is nothing specific it's going on. Besides rather it's 12s or 20s 2p or 60p the idea would be applied they same way rather it was for a electric car or something small like a bike.What exactly are you trying to do? Now you're up to 6p, which is 3x the weight of a 2p pack for a given voltage. There's no free lunch anywhere in this stuff...it's going to cost you money. A lot more than just buying a used EV.
You need to determine the kWh, Ah, weight, volume, and voltage of the pack that you need as a minimum and set maximums. Work from there.
Ok, this appears to be the video associated with those stills.There are many fiery examples of range extenders gone wrong. Good Luck to ya.
Yes, but none of those modules are connected in parallel with any other module. A Mach-E battery consists of entirely 3P modules (for the standard range) or entirely 4P modules (for the extended range), and in each case all modules are connected to each other in series.Ford Emach has various cell layouts 4p8s, 3p8s, 3p10s modules iirc.
later floyd
edit I didn't recall correctly
Made of same cells. Sure.It was always at 6p. 12s4p plus 12s 2p equals 12s6p. It fine if that's not how it works but 6p was the end goal in that EXAMPLE.
