Generally the Peukert effect is considered during discharge of lead-acid batteries, but for charging there is a similar effect. I found a detailed explanation of this phenomenon here:
http://www.smartgauge.co.uk/peukert_chg.html
and in more detail:
http://www.smartgauge.co.uk/peukert_depth.html
Since I plan to use SLAs for my tractor project(s), I want to understand fully what to expect during discharge as well as charge cycles, and to be able to calculate accurately the state of charge. I also want to be able to extend the life of my batteries as much as possible. I would consider using one of the smartgauge products, but the cost seems prohibitive at 150 to 300 British Pounds which is about $225 to $450, and I would need one for each of my proposed 20+ batteries or a way to switch from one to another.
http://www.power-store.com/?id=273
This may be of less interest to those who use LiFePO4 cells which have little to no Peukert effect, but they still have significant internal resistance which may affect the accuracy of SOC gauges using coulomb counting or A-h or W-h measurement, especially under conditions of high current charge and discharge. So I will try to propose and discuss a design which may be used for either lead-acid or lithium technologies as well as perhaps NiMH. Since it will be microcomputer based it should readily adapt to other technologies.
As discussed in the articles linked above, a simple model for a battery consists of a "pure" energy storage element and a series resistance. More accurately, the series resistance changes according to the current, similar to the tungsten filament of an incandescent lamp, and thus the Peukert effect is exponential rather than linear. The actual Peukert constant may be accurate for a fresh battery, but it will change as it ages. And the state of charge or battery health may also be determined by performing a load test and measuring voltage and current under various conditions.
So, a comprehensive and accurate means of determining SOC and end-of-life may involve accurate voltage, current, and time measurement, as well as probably temperature, and a history of charge/discharge cycles. It would also probably need a way to perform certain tests on the battery from time to time, and be able to control charging and discharging. Thus I would design this as a 12V BMS which would be semi-permanently attached to each battery (over its lifetime), and perform its functions as part of a series string of 20 to 50 batteries (240 to 600 VDC).
I'll add further details as this project proceeds, and I welcome comments and discussion so as to make this a useful product, especially for anyone who still uses or plans to use lead-acid batteries.
Thanks!
and in more detail:
Thanks!
