Hello,
I have currently bought:
Nissan Leaf Gen 2 Motor / Inverter
Zombieverter VCU
Tesla PCS and Control Board (10kw Ac charging and dc-dc converter)
Now I am to pick the most expensive part, and I am quite afraid to do so.
I have seen a good deal on a Tesla Model 3 Standard Range battery pack.
It was taken out of a car with only 5,500 miles on it and the price is $4,850.00 + $500 shipping.
I would plan to combine it with an Orion BMS.
Problem is, I don't understand how much capacity it has or how many volts it is, as it is intended to be a replacement for another Tesla.
If I look up the specs of that car, I should expect 50 Kwh with a nominal of 350v but if the cells are 5.2kwh, then It contains 9.5 cells??
Would this be a bad buy? I just would like a second opinion before I make a $5000 mistake.
The battery pack in question
Thank you very much for your time.
Zombieverter VCU
