Definitely not going to be doing 100mph in that thing... 65 hopefully... Is this leaf option the best approach or ive been watching videos of building my own battery banks using 18650 cells. And running different motors and controllers.I just had a horrible thought about that Volvo whistling along at 100 mph! - terrifying!
Good god, no.Is this leaf option the best approach or ive been watching videos of building my own battery banks using 18650 cells.
A non-plug-in hybrid has a small battery; in this case, I think it is a battery with 20 kW output power rating (to support the 23 hp motor), but the energy capacity will only sustain that for a few minutes at the most... it is likely closer to 1 kWh than 20 kWh energy capacity.I will have to check around.. I just saw that civic hybrid batteries are 144v and 20kwh... 2011+
That's 6.0 Ah x 144 V = 0.864 kWhNickel Metal Hydride (Ni-MH) Battery
Output 144v (120 cells @ 1.2v)
Rated Capacity 6.0 Ah
While the first two generations of Honda Civic Hybrid apparently had lots of battery problems, that's not the fault of the NiMH chemistry. Toyota has no problem with NiMH, which it has always used in all non-plug-in Prius variants. Honda made hybrids early, and continues to make them now and then, but Toyota is the master of reliable hybrids. You don't want NiMH for a plug-in vehicle (not enough energy density compared to lithium), but NiMH not working for the Civic is entirely Honda's fault.as far as I can tell those 20kwh 144v batteries are only in 2012+ civics. I know the 05 era had really bad issues with the batteries and most likely because it was those nickel batteries.
They switched from NiMH to some lithium chemistry, and wanted to promote the increased power rating (up by 5 kW to 20 kW, so the previous NiMH battery must have been limited to 15 kW output), but as I mentioned earlier (with emphasis on the key concepts)...Lithium-Ion (Li-Ion) Battery
Output (kW) 20
Voltage 144
Volume (Liters) 16
Weight (lbs) 48.5
The 2012+ lithium battery capacity is not specified in the promotional material or owner information from Honda, but the volume (16 litres) and mass (48.5 pounds) are consistent with a few kilowatt-hours (they're about the same as a single Tesla Model S/X module). In lithium chemistry it will have higher energy storage capacity than the same size of NiMH battery, or the previous Civic battery, but not much higher power output... and certainly not 20 kWh in that volume or mass.A non-plug-in hybrid has a small battery; in this case, I think it is a battery with 20 kW output power rating (to support the 23 hp motor), but the energy capacity will only sustain that for a few minutes at the most... it is likely closer to 1 kWh than 20 kWh energy capacity.
Honda specs for a 2005 Civic hybrid show
That's 6.0 Ah x 144 V = 0.864 kWh.Nickel Metal Hydride (Ni-MH) Battery
That's 158.4 V x 5.5 A·h = 0.871 kWh158.4 V (132 x 1.2 V) Nickel-metal hydride batteries with 5.5 A·h capacity
We are still at a point that an EV conversion is more expensive than a conventional drivetrain. If you swap in a used (rather than crate) engine to keep the cost down, and size it relatively small to suit a later hybrid upgrade, that might make a lot of sense. It's likely to take a while to build out the camper and get enough experience with it to know what you really want.What are your thoughts so far Brian? I am almost leaning towards just doing a traditional diesel motor swap and building out the vehicle completely with the camping and expedition portion and letting the EV (mainly battery) technology catch up a bit.
At this point I am looking at going with nearly the same motor that was in the sprinter vans in the 2003-2006 range. People report 20+ mpg easy with them and over 700k miles. I think I will get the 6cyl version the om648. This might be a tad big for a hybrid setup in the future but we will see what happens. I think youre absolutely right by the time I get it completely built out and enough experience with it then I will have more options and a better idea of what to do. I am just afraid at this point to jump in and throw 15-20k at the drivetrain and not end up using it for its intended purpose..We are still at a point that an EV conversion is more expensive than a conventional drivetrain. If you swap in a used (rather than crate) engine to keep the cost down, and size it relatively small to suit a later hybrid upgrade, that might make a lot of sense. It's likely to take a while to build out the camper and get enough experience with it to know what you really want.
The OM648 might be hard to find in North America - the only model I could find which would have it would be an E320 CDI from 2005 or 2006 (and later E320 diesels had a V6). The first-generation Sprinter only came with the OM612 (earlier) or OM647 (later) 5-cylinders. Although the five-cylinders are not powerhouses by the standards of modern vehicles with 5 tons of gross combined weight, they are still a lot more powerful than the C304's original engine, and the 5 tons is within Mercedes' rating for it in the Sprinter. With all of the accessories of a (relatively) modern diesel, I wonder about fitting any diesel six-cylinder into the Volvo.At this point I am looking at going with nearly the same motor that was in the sprinter vans in the 2003-2006 range. People report 20+ mpg easy with them and over 700k miles. I think I will get the 6cyl version the om648.
Back to the EV or hybrid idea...This might be a tad big for a hybrid setup in the future but we will see what happens. I think youre absolutely right by the time I get it completely built out and enough experience with it then I will have more options and a better idea of what to do. I am just afraid at this point to jump in and throw 15-20k at the drivetrain and not end up using it for its intended purpose..
So at this point I think getting it running with a traditional drivetrain and then finishing the rest of the vehicle will be my best option. (all the while keeping an eye out for a good deal on a wrecked tesla or a few of those leaf things =P)
Well I did, but it was pretty deeply buried in a previous post:No one has mentioned the Volvo runs on portal hubs, (yay) they are going to chew a bit more energy than a straight axle(boo)
With 3.44:1 ring-and-pinion sets at the differentials, and 2.06:1 reduction in the portal boxes, a motor connected directly to an axle's input will be reduced by 7.09:1...
The 6X6 configuration does add weight and complication, but I think if one wants a 4X4 of this size the C304 is the wrong place to start. It would be easier and presumably cheaper to stretch a C303 (the 4X4 model of the same range of vehicles) if there were one available.I'd be tempted to remove the middle axle and convert to 4x4.
That's fine on the street... in fact, on pavement it is only a 6X4 anyway, since the front axle drive is disconnected. Other vehicles with tandem rear axles often have a disconnect for the trailing axle so they become a 6X2 (only the leading rear axle driven) on pavement, but the C304 doesn't have this feature; it could be added for lower drag on the highway (for more range), either on the output from the leading rear axle or on the input to the trailing rear axle.Or you could leave all three axles and only drive two of them
The Volvo FD 51 transfer case (or auxiliary gearbox, in the manual) has a similar PTO setup, although there is an add-on PTO gearbox to use it; this is probably typical of transfer cases in which front and rear outputs are in line with each other, offset from the transmission output shaft. An EV conversion of the C304 could use a similar approach to mount two motors, and a parallel hybrid conversion could use the PTO to connect the electric motor (while the engine and transmission remain in the original configuration).I've already converted my LandRover & now I have plans on converting my Iveco Daily 4x4, a fair bit bigger than the Volvo and am thinking 160kwh will do me . I'll use 2 motors , one on the gearbox input to the transfer case and one the PTO output ( Both connect to the same shaft internally so turn at the same speed)
Sounds good.I found a wrecked 2005 e320 cdi for sale i should be able to get it to my door for ~$4,000. It will be my engine and transmission but I will still need to source a transfer case.
Yes Brian, the Iveco TC is a divorced TC , it would be a reasonable solution for the Volvo. it has some design issues but I have overcome these .The Volvo FD 51 transfer case (or auxiliary gearbox, in the manual) has a similar PTO setup, although there is an add-on PTO gearbox to use it; this is probably typical of transfer cases in which front and rear outputs are in line with each other, offset from the transmission output shaft. An EV conversion of the C304 could use a similar approach to mount two motors, and a parallel hybrid conversion could use the PTO to connect the electric motor (while the engine and transmission remain in the original configuration).
Why use the transfer case with two motors? Is the idea just that a large enough single motor is not available?
Don, can I assume that the transfer case would be retained for the low-range gearing? In a typical transfer case - such as the one in the C304 - low range can only be used with the front axle output engaged (which the C304 can't use on dry pavement because it isn't like the permanent 4WD of the current Iveco Daily 4X4 transfer case with its centre differential), but that could be modified. It looks like current Daily transfer case also offers two reduction stages (four ratio combinations), so it's quite a useful transmission.
That's what I was thinking of in an earlier comment about a parallel hybrid configuration using the PTO (and the motor connection point). That works with both the original C304 hardware and the SCV transfer case in the Daily 4X4, as well as apparently old Land Rover transfer cases. Unfortunately, the Volvo unit isn't with this vehicle any more, and that very capable SCV unit is enormous and expensive. I don't know what's available at a moderate cost.Yes Brian, the Iveco TC is a divorced TC , it would be a reasonable solution for the Volvo. it has some design issues but I have overcome these .
see here http://goingbush.com/iveco4.html
... the layout of the TC is ideally suited to two motors , or even keep a small diesel up front and electric at the rear.
Well that was an interesting detour...Look here where a fellow owner had added a Telma Retarder to help with braking , now if that energy wasting retarder was a motor , how good would that be . Marcus is now kicking himself as he could have bought a Hyper9 and a load of Batteries for the $20k it cost for the retarder.
https://youtu.be/SvJLherxBMU
