E38 750i has a curb weight of 3800 to 4820 lbs according to wikipedia. That is a huge range of weights and I don't know why that would be. Maybe the V12 is a lot heavier.
If you assume the /10 rule of thumb and the conversion comes out on the high end of the weight range that means 480 wh/mile and to get to 50 miles you would need a battery pack of 24kwh for a drop dead range with no accessories on. Same assumption on the light end of the range gives 380 wh/mile and a battery pack of 19kwh. Even if you strip out a lot of the stuff that makes these great cars to drive they are heavy and weight is one thing that kills EV range in stop and go driving conditions.
You will probably want an 11" motor of some kind. 150kw (output) is going to require a pretty good battery pack. At that power level the motor will probably be around 70% efficient so you will need to feed it over 200kw. You can get there by having a battery that can put out 1000 amps at 200 volts or a higher voltage at lower amps. Say you have a 340 volt pack that sags 15% under full load this would give 289 volts. A motor like the WarP 11HV can take 288 volts so to get your 200kw input you would need 694 amps. To get that voltage you need 98 cells. You could probably do this with 60AH calbs briefly. A 98 cell pack of 60AH CALB would give you an 18.8kwh pack which is close to the 19kwh minimum estimate. Using 100AH cells at 1000 amps and 200 volts would give a pack of about 74 cells for a 23.7 kwh pack size.
Guessing your usable range with this setup will be closer to 40 miles for the smaller pack and 50 miles for the larger one assuming 3800 lb car.
Not saying you shouldn't do this, but it is going to be more expensive than a smaller and lighter car. I don't think you are going to hit your budget numbers as the batteries alone will be in the $9000 range for the small pack after shipping and intercell straps, and $11500 for the large pack. A more realistic budget for this build would be about $20000 when all is said and done.
Best Wishes!
Best Wishes!
