Thank you.I've driven two cars with AC motors that utilize the vehicles transmission and clutch. There is no reason to not leverage the benefits of the transmission. The transmission does not know what's connected. AC, DC, ICE, or Hamsters
That article is in serious need of revision; out of date, and erroneous, info all through it. There are people on this site using AC with multiple ratio transmissions. It works well with smaller motor packages, like those from HPEVS, to help them move (relatively) heavier vehicles....This article makes it seem as if an AC motor can only have a single speed transmission...
KnowledgeHi, I am back with a couple of questions.
So far I have:
Motor
Drive Inverter
Controller
Transmission
Battery
Charger
Adapter
Car
What am I missing?
A
I'm here to learn. I'm young. I have no experience with EVs. I was asking for parts. I know that I need to learn more. I don't expect to just build this thing.Knowledge
Skills
Experiece
Seriously, if you are going to do this and make a "Real" race car, you should get a good (EV ?) race engineer on board before you waste a lot of time and money.
If you have time, aptitude to learn and most of all a forgiving budget, you'll be fine. Recognize that this is going to be harder and more expensive than you expect. But that doesn't make it impossible. Try to avoid spending huge amounts of money on something until you are sure it's what you want. For instance, if you have a motor in mind, go with the mindset that it's the wrong choice and prove to yourself that it's not.I'm here to learn. I'm young. I have no experience with EVs. I was asking for parts. I know that I need to learn more. I don't expect to just build this thing.
A
So if I'm understanding this right, faster discharging packs are cheaper per kW/BHP but more expensive per kWh.I just quoted a large pack made from our team supplier's lowest cost "energy" Pouch cells rated at 30C continuous.
30C Line Up
10kWH would be $9,000 (450BHP) 3 boxes
20kWh would be $18,000 (900BHP) 6 boxes
30kWh would be $27,000 (1350BHP) 9 boxes
or about $900/kWH and $20/BHP
100C
Just for comparison a drag racing pack of my 6S 4.5Ahr 100C cells
$150 each 6PX15modules = $13,500
Boxes $2,250
Total $16,000
90X6X3.7X4.5=8.9kWh
250VX100*6*4.5=675kW or 905BHP
or about $1800/kWH but only $17/BHP
but, these obviously weigh half as much and are half the volume.
Fill in your pack requirements, multiply it out and see if that's in your budget.....
Yes your choice is low $/kwh or low $/kwSo if I'm understanding this right, faster discharging packs are cheaper per kW/BHP but more expensive per kWh.
The benefit to pouch cells is that they are malleable (to an extent) so I could shape them around the space that I have remaining in the car, correct? What are the downsides?
And people on this forum tend to prefer Li-po because of the slight increase in energy density over Li-ion right?
How does one determine their discharging requirements?
What is the rated voltage on those packs? The 30c ones.
Thank you,
A
Not stupid, but it gets asked frequently. If you mean paralleling a bank of supercaps with batteries, it could help stiffen the pack a little. But it is not worth the cost, complexity, space and weight that it would consume at this time. It would be far better to use the money, space, and weight to add more batteries. To do this right would require a rather complex piece of power electronics to get all the energy out of the supercaps. But even with that it still isn't worth it. The energy storage of supercaps is not yet good enough.Sorry, I've been kind of MIA the passed couple of months. I was wondering if anyone has any experience using both supercaps and li-ion batteries in the same pack? How would that work? Sorry if this is a stupid question, I am just trying to acquire some general information.
A
