1 - 6 of 6 Posts
Hi, I’m trying to convert the two front wheels of my Berg Black Edition pedal go kart into electric powered wheels. The back two wheels are single geared, pedal powered, and I would like to leave them as is so I can still use it as a bike when I want to. The whole kart, including myself, currently weights between 300-350 lbs. I would like it to be able to go between 30-40mph. I would also like to add disk brakes and possibly some sort of suspension to the front wheels. Is a build like this possible? If so, what other stuff will it require other than the stuff on the list below (minus the suspension stuff)?
-2 hub motors (BLDC? / how much power does each motor need to get me to my target speed?)
-controller (Do I need 1 controller for each wheel?)
-speedometer
-disk brake set up
-throttle pedal
-lithium Ion Battery (How many volts do I need to run this setup plus some lights?)
Any help would be greatly appreciated!:)
Having a motor per driven wheel will make this project more complicated and expensive than reusing the current driven axle.
The easy route would be a mid-mount (normally goes near the crank) e-bike kit with a controller hacked to allow throttle control rather than pedal-assist.
Thanks for your reply! There is a more expensive version of my kart that has an electric pedal assist, but my kart is not electric at all so it has no pedal assist.
I have a really basic version and can't buy the more expensive one where I live. :(
In this case is a mid-mount still the best option? I would really like to be able to still use it as a bicycle as well!
Even making mine an electric pedal assist is not practical because I only have one gear.
I would really like to be able to still use it as a bicycle as well.
Is it possible to change the rear wheels to use an electric mid-mount and still be able to use it as a bike?
Thanks again!
1 - 6 of 6 Posts
