Hello!
For a while now, I've been planning on doing an electric conversion, but, due to various reasons, I need to make the car appear to be an ICE driven vehicle.
My question is, how can I integrate a small electric drivetrain into my vehicle without using the engine compartment?
Ive considered putting a dual shaft warp 9/similar motor into the rear subframe, or ideally the front subframe, but im not sure if that would be compatible with steering/all the stuff already in the front subframe. Is mounting a motor beneath the vehicle, directly to the driveshaft possible? How about having a motor within the engine compartment, coupled to the engine's crankshaft with a chain?
Ideally the electric drive wouldn't have to be super powerful, just something sufficient to get around town with.
any ideas? The vehicle im planning on using is an FC rx7.
Thank you!
Thank you!
