Hello guys,
I own T3 Syncro vans for 10 years now.
I have been doing all the work on them for the last 7 years.
From my first Diesel (and another 5) conversion to 110 bhp TDI conversion.
latest project was a conversion from a 2wd bus to syncro 4wd.
Through my work I have a steady supply of IFR 26650 battery packs.
So I started building my own battery packs for my Tiny house thats off grit.
Next"logical" step is building a battery pack for a EV and converting my Syncro to an electric engine.
https://vimeo.com/48452818
Specs syncro:
build 1989.
4 wheel drive visco-clutch
front and rear diff locks
Weight empty 1640 kg
Weight fully packed around 2850 kg (its a RV)
current engine a 90BHP TDI engine with 200Nm torque
It already has a electric power steering conversion.
and a disc brake rear conversion and front vented disc upgrade done.
Max speed I want to reach is 120 km/h
Cruising speed 100 km/h
I like to keep the crawling possibility (low speed terrain gear)
Range would be cool to have +/- 400km
Sollar panels on the roof could be increasing the range.
Best thing would be to make fully solar charged car...
wait 3 days drive one day something like this
I have an offer for a MES DEA Swiss 100Kw engine with controller.
Battery packs I want to build myself from the A123 IFR 26650 3,3v Cells.
I'm not sure what size packs i want to build but properly cells's that can be easily exchanged since I like to use recycled cell's.
Most people connect the engine on to the old gearbox. This might be a good option for one big engine.But the syncro gearboxes are know to be week. Thats wy it's not a smart thing to place TDI engine in there over 100BHP/200Nm torque.
I don't know if this will be a problem with the E-en
gine?
I'm also thinking about 2 smaller engines one on each differential.
It all comes down to money in the end.
So I guess I will go for the most reliable/affordable option.
any suggestions are welcome.
Ow yes we use the van to climb all over the world.
http://www.verticallife.nl
Specs syncro:
build 1989.
gine?
