1 - 5 of 5 Posts
Motor and controller and electrics in the engine bay, 12v accessory battery in the boot, should I run a new + cable to the front to run my new stuff, like power steering pump (MR2) and Brake Pump (Gast) If so what Gauge and what type of connector could I use to plug in the accessories. This is first time wiring anything so I'm a bit shell shocked at the mo, so I'll do one bit at a time, any help will be great Cheers
16 gauge is good for running the 12 volt accessories like the gast pump and stuff. I usually run a thicker gauge wire from the battery to the terminal strip with a 40 amp fuse. Make sure you get a good solid ground connection for the 12 volt system.
I went a little overboard, literally, on my first conversion and used all marine grade wiring since it had thicker insulation. Now I just use regular Auto Store grade wire.
In addition to Powerstream, Powerwerx has some cool connectors and wiring accessories including Anderson connectors and Powerpoles http://www.powerwerx.com/
That MR2 pump is going to draw some serious current, if you are going to keep the existing 944 wiring intact I would run a 4awg or larger wire from the new battery up to the stock 944 wiring and run a fused line from that to your new accessories. Make a good ground in the back, a good place is one of the stock grounds. Good luck.
ps. if you want to ditch the power steering in a 944 there are manual racks, or you can "depower" the power rack. I have an instruction pdf (too big to attach on the forum) but I'd be happy to send it to you if you are interested.
Thanks Guys, just got back off me jollydays so back into it this week, I'll be back with more questions Cheers for the help.
1 - 5 of 5 Posts
