1 - 20 of 25 Posts
Hi, I've had to out all my projects aside for some time mostly due to moving across the city, to be closer to work.
Now that I'm slowly getting settled, and a little organised, the ekart has finally come back out.
I've hooked up a temp 80v 4ah battery for the purposes of confirming operation. Then I can get to installing the perminate wiring.
Here's the issue.
I turn on the key switch, the 24v contactor engages I get a quick two flash on the sevcon powerpak then the contactor dissengages.
Voltage with key off is 78v, key on is 0.4v
Any thoughts?
Thanks
I am no expert. But I would do the following:
  1. Double check that it is indeed a 48v contactor on the coil side. It is possible it is intended to pass 48v through the contact but may operate on a different voltage on the coil.
  2. Check if your setup has the ability to disable the contactor. It is possible it is sensing a short or something similar and is disengaging the contactor as a safety measure. Maybe try disconnecting the traction battery from the contactor and see if it will remain engaged without the high voltage attached.
  3. Make sure you are seeing the expected voltage on the contactor coil (probably while you have the traction battery disconnected from step 2). I know I had an issue where the voltage applied to the contactor coil was insufficient to operate the relay.
  4. Check the current draw on the coil. While the power consumption is nothing like the traction circuit it is still significant. The available current may be insufficent to sustain the contactor operation. Although in this scenario I would expect you to be talking about blown fuses.
I doubt it is a bad contactor. A bad contactor would be unlikely to activate at all.
If I think of others I will update the post
What Sevcon gen is that ? Some have an LED that will flash out diagnostic codes from which the malfunction can be determined. I'm especially suspicious about all those different voltages mentioned. Maybe an overvoltage protection kicks in ? :)
Discussion Starter · #9 ·
Possible over voltage I guess.
The temp packs are 36/40v for Ryobi 36v tools. Currently sitting at 76.9v
Controller is powerpak pp784 (old school unit)
Contactor is white Rodgers type 586 (24v)
Found the manual for that Sevcon unit, looks like it can really operate in 43-100v range. Still reading it to see what else could be happening.
http://www.thunderstruck-ev.com/Manuals/PowerpaK SEM & MicropaK_M.pdf
Correct, that's why I wasn't too worried about the slightly over traditional pack voltage.
10.2.5 Diagnostic LED - This is mounted between the connectors on the front of the
controller. It serves as a simple diagnostic tool as explained below:
Constant illumination - No fault, normal condition
LED extinguished - Internal controller fault
1 flash - Personality out of range
2 flashes - Illegal start condition or illegal steer switch inputs.
3 flashes - MOSFET Short Circuit
4 flashes - Contactor fault or Motor Open-Circuit
5 flashes - Not used
6 flashes - Accelerator, Steer Pot or Speed Probe wire off fault
7 flashes - Low or High battery voltage or BDI cut-out operating
8 flashes - Over temperature
9 flashes - Contactor coil s/c
12 flashes - CAN bus fault
Do you have that LED ? I don't understand from the description if it's part of the wiring harness, or if it's built into the controller body.
Discussion Starter · #11 ·
It gives me 2flashes. But that could be partly because by the time the second flash occurred he contactor has already dissengaged
Controller is supposed to be wired with constant power to it, so it's the one that controls the contactor. There is more detailed diagnostics on page 21, with several conditions that would result in two flashes. Look through all the lines with 2F in them.
Discussion Starter · #13 · (Edited)
What I don't understand, is that the wiring diagram I posted up earlier, doesn't show a secondary battery system. Or another way to wire it.
It's all wired as per the diagram.
That's why I'm confused, as I've had the system function. Just not engaged the motor. As moments into connection one of my BMS fried.
I don't know why another poster mentioned a second battery. The diagram you posted clearly shows contactor being powered from the controller. No other power source should be at play. Looking at the docs, this Sevcon has a feature called "contactor chopping", which ensures 24v contactor coil supply regardless the pack voltage.
Like I said before, you need to go through those conditions and verify nothing is throwing it off. Simple things like stuck switches can prevent it from turning the system on.
Discussion Starter · #15 ·
So, I managed to get a little more sense out of the controller.
By disconnecting the 24v chopper circuit, the controller stays on (active) and cycles 2Flashes as I previously thought.
Could it simply be a bad contactor?
You mean you essentially disconnected the contactor ? It should then give you 4 flashes if that's the only issue - controller knows when contactor got stuck and/or fails to close, and will give a specific error condition for that.
1 - 20 of 25 Posts
