1 - 8 of 8 Posts
Hi, my first post here.
My name is Nir, I am from Israel and I decided to build a small go-kart for the kid.
Got 350W DCPM 24V motor and controller (YK48-2, with reverse) from tnc.
By mistake I didn't ordered the hall effect throttle and connected the throttle plug to 5K ohm potentiometer that apparently ruined the controller, only then I realized that this is a hall effect controller.
Now I need to fix this mess or buy a new controller.
My question is does anyone have the schematic of this controller (the manufacturer is Yi-Yun), or experience with a similar problem?
Discussion Starter · #2 · (Edited)
I found that the part of the controller that handles the high current works o.k. and I want to use it rather than throw this controller away, also because it has reverse.
Now I need to build or to source a PWM simple circuit and connect them together.
Any advise is welcomed.
BTW, TNC are not willing to change the controller.
Hi,
I need feedback about the suggested schematic.
In blue is the existing circuit, in red all he additions I am planning.
My questions
1. main switch (SW1) & relay (J3) - is this a common setup? the idea is to connect it to the ignition key which have 3 positions: off, on and reverse.
2. Regenerated braking - in case the kart is going downhill and the motor is acting like a generator, the diode D will allow the generating current (mostly in forward but should also work in reverse). Is that o.k.? which diode should I use?
3. Brake - suggested a relay (J4) that will disconnect the motor from the circuit and will short it so it will act as a brake. Will this damage the motor?
The circuit is 24V, motor is MY1016 24V/350W.
The kart should be very small, total weight about 50-60 Kgs.
I suppose at 24V it's ok. Not the reverse part - that's not going to work (see below).
No, diode "D" is already present in the MOSFETs themselves and has nothing to do with braking, whether regenerative or dynamic. Regenerative braking requires changing the converter from the buck to boost configuration which requires a lot more work than what you've drawn. You are pretty close to having dynamic braking, though - just add a resistor for a load (ie - don't short the motor out)
You need to insert a load resistance otherwise, yes, you will damage the motor (and probably the relay, too). Keep in mind the resistor will need to be capable of handling the peak current and power expected. Since this is a small motor you could probably get away with a bank of cement-filled resistors (5W to 10W) that comes out to around 0.5 to 1 ohm and at least 50W (the peak power handling capacity for a few seconds will be at least 4x that amount).
Do you mean the reversing circuit will not work? that part already exists and reversing the motor well.
O.k, I will remove the diode.
O.k.
Ok, I built a PWM circuit using schmitt trigger from here (only used cmos 4093 instead of ttl 7414) and the circuit seems to work fine - I don't have oscilloscope so I checked it with a larger capacitor so I could see the on/off duty cycle visually with led going from 0 to 100% and then I replaced back to normal frequency (about 3KHz).
It seems to work - when I change the potentiometer (throttle) the motor speed changes but the speed is not stable i.e. without touching the potentiometer the motor speed also goes up and down (mostly up).
I suspect the fault is with the PWM circuit - too simple perhaps. Any advise about PWM circuit which is more dedicated to DC motor?
Here is a pic of the circuit.
1 - 8 of 8 Posts
