Hi all
By interest and because I'm tired of don't know the real performance capability of the Volt battery, I've decided to test the power of the Volt battery pack.
Of course, I don't have powerful/accurate/costly test equipments, but I have a 125 Kw electric Smart Fortwo
So, the plan is to disconnect my current battery pack and drive my car with 1/4 of the Volt battery pack (24S for 90v and 45Ah, 84 lbs battery). I will set the Soliton 1 at 450 battery Amps (10C), record the acceleration and if the result is promising, try at 675 battery Amps (15C).
Tesseract has repeat many times that the Soliton isn't a laboratory module, but a fairly accurate result is still better than nothing.
After, I will be able to confirm than the Volt battery will be able to provide 4 times the peak power I've found at 15C.
If you have other tips and suggestion, let me know.
Oh! And let me few days to do the test... I still charge the pack with my 8S 300w charger tonight
