I thought it would be a good time to start my build thread since I am well into my build. It is a SMALL twin motor setup in a very light car to eliminate the need for a shifter. Electrically operated two speed with electric reverse. This elaborate setup is more to satisfy my curiosity with electric cars and not meant to be an economical build. I felt that I can put a twist on the drag car dual motor setups to make a clutchless and shiftless electric car that anyone can jump in and drive. We will see...
Stats:
Wombat fiberglass body on a VW frame
Projected weight = 1800 pounds
Motor and Controller = Twin 7 inch Warp motors with Warp Drive controller
Contactors = (1) pos, (1) neg, (3) series/parallel, (4) forward/reverse, all EV200 with aux contacts.
Batteries = 48 CALB 100AH lithium
Charger = ?
BMS and car controls = MOCOSO car pc with touch screen interface to a fusion brain and aux boards. Digital outputs controlling headlights, flashers, running lights. 13 analog inputs to monitor 12volt groups (4 cells) of the pack and one channel for chassis 12 volt battery.
I want to thank everyone on this forum for helping me, especially a couple of you that helped me privately.
Stats:
Charger = ?
