I left the power steering pump on my 1996 Civic. I plan on attaching it to the rear shaft of my motor, but haven't yet cause I am lazy. It is somewhat harder to steer, but after 1000 miles of EV driving I am not urging myself to install it yet.
LOLTo keep your existing rack you could remove the pump and just join the in and out pipes together on the rack.
I thought about the MR2 pump as well, but the problem is that the MR2 is light up front and if you plan to put lots of stuff in the front (like batteries) it weighs down the front a lot adding strain to the power steering. Also, the wider your tires are upfront the more strain there is. So you may be going through MR2 pumps very often if you go that route. There's a few power steering pump kits for electric cars that would be good for this and will handle the extra weight and strain.For a little money you could replace the pump with an electric pump. A number of small modern cars have them and the common one that is used is from the Toyota MR2.
Personally I would either change to electric power steering or change the rack to a manual one from the same model. It would have a better gear ratio to make for easier steering.
After many years of conversions, I have found that the stock P/S pump driven by the front motor shaft works surprisingly well. I have done fords, gm, chrysler, and mazda with P/S and this has worked fine.
The amount of motor rpm needed to build up pressure for assist is less than 50 rpm. Pretty much as soon as the motor starts turning you have assist. Everyone that has seen this on my conversions are surprised.Yes this will work for parallel parking once you start to move. Yes, you cannot have assist just sitting in one spot unless you spin the motor slightly (but you shouldn't be steering without moving anyhow)
I would suggest that anyone with a power steering donor try it this way before spending alot of time and money on electrical assist that more than likely would not be needed, and adding a drive pulley and bracket is not all that difficult on most conversions.
Oh, and yes automatic transmissions work without an auxilliary pump also!
Mike
www.EV-propulsion.com
My MR2 has 205 40 17 tyres up front, that is reasonably wide.I thought about the MR2 pump as well, but the problem is that the MR2 is light up front and if you plan to put lots of stuff in the front (like batteries) it weighs down the front a lot adding strain to the power steering. Also, the wider your tires are upfront the more strain there is. So you may be going through MR2 pumps very often if you go that route. There's a few power steering pump kits for electric cars that would be good for this and will handle the extra weight and strain.
Also, if you do decide to go with a pump, make sure you have a good 12v dc/dc converter. They can spike 60-70amps at some points. I'd say if you don't want to go through the hassle, go with the manual steering rack!![]()
That's not a bad idea... I still don't think that the pump is going to be good enough if you have too much weight on the front. It's meant to deal with a mid-engine light-weight car. Adding 400Lbs of batteries and misc equipment is a game changer for that pump. Just my thoughts on it, though. If you got a couple just lying around, then I'd say go for it. But if you're purchasing, you should do it right the first time and buy just one pump.My MR2 has 205 40 17 tyres up front, that is reasonably wide.
Run the pump from a small 12v battery topped up by the dc/dc converter. The battery will cope with the power spikes and the rest of the time when you are not doing much steering the battery will be recharged. That is assuming you do more straight line driving then you do parking and slow cornering.
Anyway, I am biased as I have one factory fitted and so I have to live with it.![]()
I love this concept, but I am mechanically and electrically inept. Is the installation fairly straightforward? And is it even compatible with my existing system? I would hate to buy the $170 dollar electric pump and have no clue what to do with it hahaMy MR2 has 205 40 17 tyres up front, that is reasonably wide.
To be honest I wouldn't know how difficult it would be. My assumption is that it has been used by so many converters that it must be easy and well able to cope with the extra loading on the front axle.I love this concept, but I am mechanically and electrically inept. Is the installation fairly straightforward? And is it even compatible with my existing system? I would hate to buy the $170 dollar electric pump and have no clue what to do with it haha![]()
