In starting this thread, I'm going to advance a possible solution to the problem of the limited battery resources being tied up in little used EV conversions and other projects. The wave of EV acceptance is growing at an amazing rate. And, it seems to be nowhere near reaching its crest. If people can't get an EV, they want to build one or convert an existing vehicle. Hence, this Forum. The problem is, in some of these builds and conversions, the batteries are not being used to their maximum potential. Unfortunately, this contributes to skewing the already limited battery supply to a situation of even more scarcity and higher prices. In part, this is normal Economics 101: excess demand, panic buying, hording. etc. Part of the problem is unique to today's batteries
First, some background. Skip this paragraph if you already know about battery life. Batteries as they exist today have a cycle life as well as a calendar life. The batteries die from normal degradation, over time. Seals fail, electrolyte leaks out, contaminants in the materials reduce capacity, corrosion sets in, etc. 8-10 years to a fixed reduced capacity seems to be the normal warranty for current OEM EV lithium batteries. Tesla thinks this might be closer to 25 years for some of their latest batteries. Elon Musk has talked about "million mile" batteries in the future. Let's hope this true and part of a trend for the future. The batteries are going to fail at some point, mostly unrelated to how little they are use. So, if the batteries are used in a little used classic car, or other little-use application, much of the lifetime battery storage capacity is wasted. In the big picture, this drives up the cost of batteries and reduces the number of them available for other uses. These are uses that could make better use of the lifetime battery storage capacity and hasten the reduction of petrochemicals as part of our energy future.
I propose an idea that has the potential of a win/win/win solution for this problem. Use the converted classic car(or other low-use battery application) as an addition to or a replacement for the Tesla Powerwall and the like. For now, let's call it the Powercar energy option. Off grid solar, wind, or microhydro? Use the otherwise little used batteries in the car for the primary or secondary energy storage. Grid tie solar? Use the car battery for night time use, back-up during outages, grid peak usage sell back, other uses? I suspect the technology is already available for this type of application. If not, somebody should build a safe, convenient way of doing this.
At any point, the unplugged erstwhile Powercar could be driven away to a car show, parade, or to buy a loaf of bread to impress your neighbors(if you're into that kind of thing). Are there tax incentives for the Powerwall? Could they be applied fairly and proportionally to a Powercar?
What do people think? Sounds like a win/win/win to me.
