Somethings that I think that every EV hobbyist should know about Powerglides. I'm not an expert but these are things I have learned by reading and experimenting or have seen done by others over a lot of years.
The powerglide could probably be the most versatile transmission there is for an EV. Here are some things to know.
The powerglide in all of its varied forms is Flintstones simple and rock solid technology.
Properly set up it should allow smaller lighter motors, leaving GVW for batteries.
The torque converterless manually shifted powerglide trans has been extensively developed by roundy round racers. The parts for a converterless conversion to a manually shifted power glide can be found in Jegs or Summit and many other catalogs. These transmissions do not slip or waste power the only loss is in running the pump, multi gear manuals probably consume more power dragging all those extra gears through the trans oil.
There are a number of versions available with and without clutch pedal.
You can buy one complete, overhauled Beefed up and ready to install for less then you pay for a good controller.
With an aluminum valve body they are as light or lighter then many manual transmissions plus you are only carrying around what you need, e.g. Low, High and Reverse.
The roundy rounders use them for just that reason
Those who wish regenerative braking and worry about clutch packs disengaging during decel there are systems in the roundy rounder version that allow push starting. Those guys don’t have starters, they weigh too much.
Solenoid shift controls are available.
The front pump and input shaft coupling adapters are available with common well known bolt patterns, so motor to trans adapters should be easy to fabricate.
A good selection of low gear ratios is available.
They can be made to fit virtually any longitudinal drive train. I wouldn't rule out FWD either, somebody out there probably makes some form of adapter.
They can be unbelievably strong. Drag Racers regularly run 800 -1000 hp through them with BIG torque.
The trans is not too long, you can saw off the bell housing and put a readily available shorty output shaft and end cover on it. and have a trans that is about 14 inches long from input to output.
There are a number of bolt on bell housings (they bolt to the front pump after you saw off the stock bell housings) out there for common Ford Chrysler AMC add many other engines.
The trans can be, with a little re-engineering to bearings, easily adapted to sidewinder configuration for those who want to build big 2 and three wheelers.
Finally you can still build a completely new powerglide from scratch. Every part including cases are still available in heavy duty reinforced form, brand new from somebody.
I've just really discovered EVs but I'm + 60s and getting sick so I can't work with this big stuff for myself anymore. I have my own little EV stuff.
I hope some of you younger people take another look at these transmissions. I know switching out a perfectly good transmission sounds like extra trouble, but if it is measurably better it might be worth a look. After all a lot of you are switching out perfectly good ICEs for the same reason.
I'm sure there are many of you with pros and cons and some with better information then me. That’s what discussion forums are for. We can all learn something
