Hello everyone!
We've just released PowerWatcher 3.0 Yay
This device collects various data from your electric transportation device and displays it on your Android smartphone.
You can control the energy consumption of the battery in different modes of movement, receive a lot of useful information in real-time such as:
- Amper/Hours Spent | Total Amper/Hours
- Watt/Hours Spent | Total Watt/Hours
- Amper/Hour Recuperation | Watt/Hour Recuperation
- Charge Level
- Cycle Count
- Min Voltage | Max Voltage
- Max Current
- Max Speed | Average Speed
- Temperature
- Distance
What's new in PowerWatcher 3.0:
- The device now has a new, more compact design.
- Increased power voltage (5 volts). This allows charging your phone from the device when it's on.
- Added RS485 bus support. Now you can extend the device functions using the external sensors.
- Optocoupler is used for the speed sensor.
- The device comes in two variants depending on supply voltage.
You can find more detailed info about the device on our website: https://powerwatcher.net/
Pricing:
- PowerWatcher 3.0 High Voltage Kit: $83.90
- PowerWatcher 3.0 Middle Voltage Kit: $67.53
The Kit includes the following items:
- PowerWatcher3
- Bluetooth adapter
- 2 thermal sensors
- RS485 Voltage Sensor
- RS485 Current Sensor
- Wires
Differences between High Voltage Kit (HVK) and Middle Voltage Kit (MVK):
1. HVK measures voltage using an external voltage sensor, which can measure up to 600 V. MVK measures voltage using an internal sensor.
2. HVK supply voltage is from 12 to 30 V. MVK - from 30 to 200 V.
3. HVK uses a digital current sensor (RS485). MVK uses analog current sensor.
You can order the device in our shop: https://shop.emkit.net/shop/category/powerwatcher3-1
If you have any questions, please reach out in the comments below. We'd like to hear from you.
Here are some photos of the device and the Android screens:
Also, you can see it in action here:
https://youtu.be/Xv0pa3uMPN0
https://youtu.be/OWRqpA9aVyI
- Charge Level
- Cycle Count
- Max Current
- Temperature
- Distance
Pricing:
- PowerWatcher3
- Bluetooth adapter
- 2 thermal sensors
- Wires
