Prestolite forklift motor for gokart
4716 2
Hello,
Im building a pretty extreme gokart
Pushing around 100volt and 500amp max.
Ive been looking on some motors, but there are VERY little info about rpm/volt. kw etc..
How are these forklift motors
https://www.ebay.com/itm/Prestolite-Drive-Motor-2755172-/232255847617
https://www.ebay.com/itm/Prestolite...411792&hash=item51b0c97df5:g:xToAAOSw44BYLS~Y
https://www.ebay.com/itm/Prestolite...917898&hash=item3f5dd8dc0a:g:THEAAOSw711Zesao
https://www.ebay.com/itm/Prestolite-570-433-201-MJQ-4007-36-V-DC-Electric-Drive-Raymond-Forklift-Motor/360721994721?rt=nc&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D41375%26meid%3D9d055529c3fe45c58cbd1047c89ee8fc%26pid%3D100005%26rk%3D6%26rkt%3D6%26sd%3D350858345973&_trksid=p2047675.c100005.m2219
And what are the difference on the MTY4001RU and MTY4001?
Dont you gusy think the MTY4001 looks better than the RU cause of the isolation and copper colored wires?
1 - 3 of 3 Posts
It appears that the "RU" suffix indicates remanufactured. The "MTY" defines the electric design. I think that is a 7.2" frame dia, 33 slot, 7" core. No doubt a fine robust motor maybe big enough to rip a cart apart. Likely 100+lbs.
The MJQ motor is a 7.2" dia frame also but uses a 5" core and 45 slots with a bit narrower brush. Likely ~15lbs lighter. Ultimate torque lower by 5/7 vs MTY. Speed-torque performance similar but derated current wise but might tolerate higher voltage.
MJT is a 6.6" dia motor using a 37 slot armature 3.25" core. Basically a golf cart size motor with real guts. It might come in less than 50lbs. Unless you just want to burn the rubber off the tires, this is your best choice of the three.
They're all series wound so you need over speed protection or flack jacket.
Good luck.
major
Good luck.
major
Superb :)
I think it was 86lbs.
What is the difference between 33 slot and 45 slot and 5"core and 7"core?
And do you know the rpm/per volt?
I do want burnout, so i think the MTY suits me better.
As im may run as high as 144v and 500amp burst, i think the MTY will fit me better.
You said speed protection.
Im may use a Paul and Sabrina controller, with this motor.
What kind of speed protection where you thinking about?
I also wonder what kind of throttle i should use with the controller :S
OHH i almost forgot
https://www.ebay.com/itm/Prestolite...tor-Raymond-Forklift-/272157432842?rmvSB=true
https://www.ebay.com/itm/Prestolite...ymond-Forklift-Motor-/350858345973?rmvSB=true
The RU version looks cleaner, but it has some rust on the brush wires? Is this a bad sign? and which of them would you choose?
Thanks for all good info :)
Best Regards
Thomas
1 - 3 of 3 Posts
