1 - 11 of 11 Posts
Please provide dimensions, quantity (used in motor and that you want to buy), and any markings on the existing brush. Photos of the brushes, holders and comm will help.
https://trupar.com/p/hyster-forklift-motor-brush-single-0289345
Something like this? Not sure about this one. Need info from you and also from seller.
major
Hey Major, :)
I got these,
Do you need some meassurements also?
Dont these look worn? Will i feel an increase in speed and torque if changed?
Hey Major, :)
I got these,
Hi Pota,
No, those brushes don't look worn to the point of needing replacement. And new brushes will not give you increase in speed and torque.
The pictures indicate to me abuse. Repeated overload and arcing without normal (within rated) running time to re-establish proper commutator film and brush face seating. Proper comm surface should show a uniform dark gray patina and brush face a smooth shiny surface.
If you are the one responsible for the abuse, you need to examine the application or lower your expectations regarding motor durability and service life.
Regards,
major
Hey Major,
I got these,
Hi Pota,
Regards,
major
Hey,
No i havent used the motor. What should i do? Could i use a 600-1000 sandpaper and spin the commutator to repolish the surface? Then connect the brushes and let them run on 12v for a period of 24hour?
Hey,
First off, try this. Reassemble the motor. Clamp to bench. At 12 VDC, run for 30 or 40 hours. The current even at no load will be high enough you'll need a large truck charger with good size battery floated across it. Use a fan to keep motor cool.
Take some close-ups of comm surface and brush face. Post them.
If that isn't helping, next try a dressing stone. Then using abrasive cloth. Lastly have it turned and undercut. In the meantime, research commutator/brush care and service on the web or library.
major
Hey,
major
Cool. Ill give it a try. Will a better resurfaced com give more power?
And btw Major. Regarding the rotation of the motor when on. If you look at the picture.
I spun the motor counter clockwise of the brush on the picture. Is that wrong? Or should it go clockwise?
Im asking this because the brush has a special shape, (like a \ where it touches the com ) so i was wondring what rotation it has been doing to form that shape, i guess its been formed like that after years of service 🙂
Little to no affect w/r/t power.
The brush is designed with the curved surface and comes that way new from the brush vendor. It is purposely angled and suitable for either rotation direction.
major
major
Good :)
When time comes, do I buy the brushes you posted? Was that the correct one?
Are there other things i can do to the motor to make it fresh and clean so it makes more power like a new one?
1 - 11 of 11 Posts
