Hi all
Starting a thread to collect all available info on the 3rd Gen Prius transaxle in one place.
If you have any info, links, documents etc please post here.
Prius Gen 3 wikipedia page
Prius Gen 3 workshop manual, pdf 7595 pages, outline links to different areas/topics
OEM guide on how to check, remove and replace all parts of the car. No info on actual transaxle disassembly.
Oak Ridge National Laboratory Evaluation of Prius system. See attachment OakRidge_2010Prius.pdf
In depth analysis of electrical motor system, mainly focusing on mgr2. Testing of motor performance at various power levels.
Prius Gen 3 inverter control board for sale by EVBMW and support thread at openinverter forums.
This is by a wizard that you really want to be following. Youtube channel
Also watch him pushing 300 kW+ through a very similar, if not the same?, Yaris inverter. What got me interested in the Prius conversion.
Conversion thread by forum member jddcircuit from before the EVBMW control board was available.
Had a vehicle running under mgr2 power, though thread has gone quite since 2011.
More progress was made on a sexier Toyota MR2 donor car, thread, gone cold again since 2015.
From my (noob) understanding of these resources the transaxle and inverter should be good for 100kW of power via both motors.
With the possibility to peak higher than this.
Limited by stock gearing to 42mph or 60kW at 113mph using only MGR2. My goal from here is to pick one of these up and try to overcome the gear speed limitations of MGR1 and its rpms. Ideally by altering the gears inside the unit or by locking one diff output and sending the other though some other transmission or the like before the wheels.
Again people with better understandings of this and resources do please post it here.
Thanks
Thanks
